Edited by Roark, 28 January 2016 - 02:21 PM.
Posted 28 January 2016 - 02:18 PM
Posted 28 January 2016 - 10:33 PM
You should look for controls that regulate compressor inlet pressure. Apply same, but control the column pressure. Controls will vary depending on the compressor and driver. But application to column pressure control should be obvious to you. And, you should be able to find better examples than the one you have shown us.
Posted 29 January 2016 - 01:51 AM
Hello Bobby,
Thanks for your reply. Yes, controlling the pressure of the column via the inlet pressure of the compressor seems like a straightforward control method, probably the first thing that I could imagine. However, the sketch shown is the actual process I am trying to fully figure out. It's not that I aim to optimise or improve it: it's a proven NGL recovery process (firstly licenced by Ortloff but now it's open art) which I am trying to fully understand.
By the way, I have just realised that it may not be obvious from the sketch that the Turboexpander (TEX) and the residue gas compressor (RGC) are coupled, both impellers are mounted on the same shaft hence the work extracted by the expander (less some 1% friction losses) drives the residue gas compressor.
Posted 29 January 2016 - 11:28 PM
The overall plant controls can be quite complicated. There is typically a residue gas compressor to further boost the gas pressure. This is due to the limited upper pressure range that the NGL recovery column can operate. You must set the constraints to be met before you can implement controls for the plant. Including the column pressure control. In cases where the plant must process whatever inlet flow arrives, then the column pressure can be controlled by the expander capacity control, which is typically speed control. Residue gas flow/pressure control will then be manipulated to maintain the cold separator pressure. So, the answer to your query is "it depends....."
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Surge Analysis-Control LogicsStarted by Guest_stu_* , 30 Dec 2024 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
