Hello Everyone
I am trying to simulate the LCO2 unloading from a tank and then inject it to an EOR site.
LCO2 is available at -20 C and 20 bara which is subsequently heated and pumped to final conditions of 5 C and 80 bara. When the LCO2 is pumped out of the storage tank, the pressure in the tank drops and we need to give a vapor input stream to the tank in order to maintain the tank pressure and avoid any dry ice formation.
My question is how do we calculate the vapor input to the tank in order to maintain tank pressure? Is there any rule of thumb? I believe, heat leaks to the tank, tank size and density of LCO2 may be the important factors in determining the vapor quantity input to tank.
Will appreciate if you can share your thoughts/experience on this.
Thank you.
uxahid
