Dears:
Anyone can clear me that one that coolant in double mechanical seal fails , we can run the unit for 30 minute until stand by pump would put on service?
Best REGARDS
Posted 29 February 2016 - 09:01 AM
Dears:
Best REGARDS
Posted 29 February 2016 - 09:41 AM
Your writing: "Anyone can clear me that one that coolant in double mechanical seal fails "
does not make any sense in English.
Do you mean to ask the following question:
Can anyone explain to me why the coolant in our double mechanical seal fails?
Posted 29 February 2016 - 10:57 AM
Posted 29 February 2016 - 12:21 PM
Mr. Rahimzadeh,
Relevant mechanical seal vendor is the best reference to which you can ask the matter...but at a glance it can be said that there would be no or very limited time for running the working pump without sealant...
Posted 29 February 2016 - 06:17 PM
Mr Rahimzadeh ,
No sealant = troubles ! You should have a way to control the sealant flow (pressure) . Quite often there is a pot to keep the sealant ( thermosyphon) with a sight glass and failure are detectred by Operators patrolling or sensors.
https://www.flowserv...oir_Install.pdf
Edited by breizh, 29 February 2016 - 06:31 PM.
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
![]() Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panoska_* , 23 Feb 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
Liquid Seal Drum DesignStarted by Guest_maginaga_* , 12 Oct 2023 |
