I have to vaporise ethylene feed (mixture) and I am thinking of using kettle reboiler.
I have to simulate it in Hysys and my tutor said it is ok to simulate it using a normal heat exchanger (Hysys does not have K shell). Vapor mixture would be sent to the reactor.
However for the detailed design which I have to submit, I have to provide the calculations and right equipment to use. I am thinking of using AKU heat exchanger. Steam would be used to heat.
After reading the attached I have some questions.
1)Critical Pressure is needed for Mostinski's Equation. For mixture, is it ok to use weighted average from valves of single component in Hysys for calculations?
2)They took liquid level as 500mm and showed a freeboard of 340mm which is satisfactory (More than 250mm is ok i think). How did they arrive at 500mm? Is there any calculation and how do they ensure liquid level will stay there?
3)My PFD in Hysys would be recycle ethylene feed + fresh ethylene feed -> heat exchanger -> output from HX to reactor. I saw many kettle reboiler attached to a column. Is it necessary?
4)I previously done a design for AEU HX but in the attached, I find that there is missing design parameters like pressure drop in tube and shell / ft factor / tube side velocity / L/D ratio. They also do not iterate on the estimated U values. Are these parameters not applicable in kettle reboilers and what other design considerations I should take account of?
5)Also they just put a surface tension estimated of 9.7*10^-3 N/m. Is it the surface tension of the butane liquid surface? How did they get the value and how do I come up with a value for my mixture? And does the 326 *10^3 for lamda in modified tuber equation come from latent heat?
As you see I have a lot of questions and I thank you for taking your time to help me!
Edited by aamaterasu, 01 March 2016 - 10:24 AM.
