Hello all ,
I'm wondering please what we should call the Cp/Cv ratio for liquid , it's called gamma or k ratio ?
Posted 16 March 2016 - 05:43 AM
Hello all ,
Posted 16 March 2016 - 06:20 AM Best Answer
Dear Dana,
Both Gamma and K are used to denote the Specific Heat Ratio.
The Specific Heat Ratio is usually denoted by Gamma by Chemical, Process, Aerospace Engineers.
The letter K is usually used in place of Gamma by Mechanical Engineers, Thermal engineers and those more concerned with thermodynamics.
Shantanu
Edited by shantanuk100, 17 March 2016 - 03:01 AM.
Posted 16 March 2016 - 06:33 AM
Call it the "specific heat ratio". Everyone who has the knowledge knows what that means.
Posted 16 March 2016 - 09:17 AM
Another question :
I'm wondering please if anyone know the difference between Cp/Cv (ent method ) and Cp/Cv (gamma) on hysys ?
Thanks a lot !
Regards !
Posted 16 March 2016 - 11:58 AM
Appears here a reality about the OP qestion has been forgotten...!
Contrary to gases in liquids, as is the subject of OP question, because are supposed to be incompressible Cp and Cv have almost same values hence only a single value of specific heat is applied for them; then the specific heat ratio would be almost not applicable...
Posted 17 March 2016 - 02:43 AM
Dear Dana,
1. I had failed to notice you mention liquid in the question. That is a very important point as Mr.Fallah has rightly pointed out.
When you consider gases, this ratio is called Gamma or K as mentioned earlier.
2. For liquids, the Cp and Cv become equal, so the ratio of Cp to Cv is always 1. So it doesn't have a specific name as such because it is always 1.
3. Let me illustrate, the Enthalpy of a system is defined as follows --- H = U + PV
So , for getting specific heat capacity at constant pressure we partially differentiate wrt to temperature (under a constant pressure process).
Partially differentiating the above equation (H = U + PV) at constant pressure, we get,
dH/dT = dU/dT + d(PV)/dT
dH/dT = dU/dT + PdV/dT + VdP/dT
Since it is a partial differential at constant pressure, we get the partial Del (P) = 0
And also since liquids are considered almost incompressible, we also get Del (V) = 0
So this gives,
dH/dT = dU/dT for incompressible fluids
Cp = Cv
4. If I were to explain it in physical terms, the change in enthalpy of a system is accounted for by corresponding change in the internal energy (U) of the system, and by the work being done (PdV Term), and by the VdP term.
But since Cp is defined at a constant pressure (dP=0) and since the volume change of incompressible fluids is too small for any considerable work to be done (dV=0), both those terms become null and your enthalpy change has to then only go into changing the internal energy change and nothing else. So, now, since the changes are equal, their respective ratios with temperature differentials will be the same thus making your Cp equal to Cv.
4. Now since your Cp and Cv become equal, their ratio is always = 1.
So for liquids, there still exists a specific heat ratio, but is usually always 1, so it doesn't make much sense to give it a name. It can still be called by Gamma or K, but even then, would always equal 1.
So no specific name is ever needed or used anywhere (Only in the case of liquids)
Cheers,
Shantanu
Edited by shantanuk100, 18 March 2016 - 12:44 AM.
Posted 16 May 2016 - 06:14 AM
I need to know temperature of natural gas after pressure reduction.
Input gas pressure is P1=70 Bar G and temperature is T1= 33 degree celsius and pressure after reduction is P2=25 Bar G.
The equation that I have come across is T2 /T1 = (P2/ P1)^(k-1)/k
On site the temperature after reduction is 11 degree celsius.
Can someone help in how to obtain the desired result from above equation or is their any other equation.
Posted 16 May 2016 - 06:23 AM
Make sure you are using the proper unit , Pressure in bar absolute and T in Kelvin , for cp/cv a value close to 1.3 should be good , I found 1.27 in litterature .
Probabaly good also to introduce the Z factor in the calculation .
P*V ^k=cte & P*V=Z*R*T
Note :
a)This should be an iterative calculation with assumption on Z2 .
I've added a calculator to calculate Z .
b)The composition of natural gas is also needed to calculate Z because it's a mixture.
http://checalc.com/s...aturalgasZ.html
Edited by breizh, 17 May 2016 - 01:05 AM.
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Ratio Pressure Drops-FlowratesStarted by Guest_panoska_* , 08 Nov 2024 |
![]() How To Use 'choking Pressure Ratio'Started by Guest_Sansan_* , 27 Oct 2024 |
Hysys Dynamics Model - Manipulating Split RatioStarted by Guest_OchemWhiz_* , 21 Sep 2024 |
![]() Ratio Heat To ElectricalStarted by Guest_panoska_* , 02 Dec 2023 |
