Mass Fractions To Mol Fractions
#1 EngRichard
EngRichard
  • 4 posts
Posted 16 March 2016 - 02:33 PM
I'm focussing on the bottoms product of a continuous distillation column. In the column i'm trying to separate water and ethanol. I don't know W (the bottoms product flow rate), but I know that I need a bottoms product composition of water(99.5% by mass) and ethanol (0.5% by mass). Is it possible to covert these mass fractions to mol fractions, so I would know the composition of the bottoms products in mol fractions rather than mass fractions? If this can be done, can someone explain how?
Thank you!
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 16 March 2016 - 04:00 PM
Wi = Mi*Xi / (M1*X1 + M2*X2 + ... + MiXi)
where:
Wi - mass fraction of component "i"
Xi - mole fraction of component "i"
Mi - molecular weight of component "i"
and the other way round:
Xi = (Wi/Mi) / (W1/M1 + W2/M2 + ... + Wi/Mi)
The details you can find in most of (if not all) Chemistry and Thermodynamics textbooks.
#3 breizh
  • 6,715 posts
Posted 16 March 2016 - 04:42 PM
To support you work and understand :
Consider 100g of product >>>> 99.5 g EToh +0.5 g H2O >>>>
Mw EtOH =46 g/mol & MwH2O =18 g/mol
Nbre of Moll EtOH = 99.5/46
Nbre mol of H2O =0.5/18
%mol EtOH = (99.5/46)/(99.5/46+0.5/18) *100
%mol H2O =100 -%mol EtOH or (0.5/18)/(99.5/46+0.5/18)*100
Hope this helps
Edited by breizh, 16 March 2016 - 04:43 PM.
#4 shantanuk100
shantanuk100
  • 104 posts
Posted 17 March 2016 - 02:00 AM
Hello Engrichard,
You have 99.5 % water by mass and 0.5 % water by mass.
Which means you have the ratio of their weight fractions.
Mass fraction of a component is the component weight's ratio with the total weight.
Similarly mole fraction is the ratio of the component moles with the total moles.
So, you have 99.5 wt% water and 0.5 wt% ethanol.
This means the weight ratio of water is 0.995 / (0.995+0.005) = 0.995
and weight ratio of ethanol is 0.005 / (0.995+0.005) = 0.005
So for mole ratio we need to consider the moles of substance, which is the weights divided by their respective molecular weights.
So your mole ratio for water is (0.995/18) / (0.995/18 + 0.005/46) = 0.05527 / (0.05527 + 0.000108) = 0.998 = 99.8 mole %
and mole ratio for ethanol is (0.005/46) / (0.995/18 + 0.005/46)  =  0.000108 / (0.05527+ 0.000108)  =  0.002 = 0.2 mole %
Shantanu
Edited by shantanuk100, 17 March 2016 - 02:01 AM.
