I am working on a gas sweetening plant and venting acid gases containing 99% CO2 and 1% H2S in air. We are using a vent stack of 250 feet height for this purpose. We want to carry out maintenance job on this stack and would use a flare stack of 100 feet for venting purpose. Will it be safe for venting H2S gas at this height?
Posted 22 March 2016 - 07:00 PM
Posted 22 March 2016 - 11:11 PM
You cannot use the 100 feet flare for venting. Since the dilution will be less. You can refer ASHRAE handbook on Heating, Ventilating, and Air-Conditioning Application, chapter 44 (2007 edition).
Posted 23 March 2016 - 12:47 AM
A dispersion model will give you the answer . You may find tools using Google.
As stated above I 've the " feeling " that is not achievable .
Those materials are very harmful.
Edited by breizh, 23 March 2016 - 12:48 AM.
![]() Free Screen Vent SizeStarted by Guest_R2012_* , 28 Jun 2024 |
Vent Mast SimulateStarted by Guest_Chitchat_* , 19 Jun 2024 |
![]() Vent Sizing Using GooseneckStarted by Guest_mychemicalromance0425_* , 23 Feb 2024 |
