I have a problem in calculating the heat transfer area required in a shell and tube heat exchanger. The problem states that only 90% of heat given up by hot fluid is recovered by cold fluid. I have calculated the overall heat transfer coefficient (U) and the logarithmic mean temperature difference (delta T). The quetion is, should I use equation 1 or 2 to find the area ?
aa.jpg 24.5KB
2 downloads
Many thanks
Edited by Alaaeldin55, 23 May 2016 - 05:49 AM.
