Trouble In Simulating Maleic Aanhydride In Hysys
12 replies to this topic
#1 Fiha
Fiha
  • 7 posts
Posted 27 May 2016 - 12:54 PM
I'm simulating Maleic Anhydride production in hysys
I'm using PRSV fluid package
and I've defined 3 kinetic reactions in reaction set. main reaction and 2 side reactions.
I used plug flow reactor .
It converged but there is no conversion.
I tried increasing feed temperature also but it didst work
No maleic anhydride is being produced
Can you help me solve it?
Thanks in advance
  • 6,936 posts
Posted 28 May 2016 - 01:05 AM
Let you try google & youtube
 :Maleic anydride hysis , you will get some info .
Hope this helps
Edited by breizh, 28 May 2016 - 08:50 AM.
#3 Fiha
Fiha
  • 7 posts
Posted 28 May 2016 - 02:02 AM
Let you try google :Maleic acid hysis , you will get some info .
Hope this helps
I didn't find anything related to it on google
#4 breizh
  • 6,936 posts
Posted 28 May 2016 - 06:38 AM
Hi Fiha ,
I found Youtube quite supportive :
Hope it will help you and others.
#5 Mahdi1980
Mahdi1980
  • 182 posts
Posted 28 May 2016 - 08:58 AM
Fiha,
Please let us have your simulation file and a scan of your information about kinetics of reaction.
Mahdi
#6 Fiha
Fiha
  • 7 posts
Posted 28 May 2016 - 01:01 PM
Fiha,
Mahdi
Attached is reaction kinetics and pfd
#7 Mahdi1980
Mahdi1980
  • 182 posts
Posted 29 May 2016 - 01:31 AM
Fiha,
good. But send your hysys simulation file to check what wrong is it leading to no conversion. Ok?
#8 Fiha
Fiha
  • 7 posts
Posted 29 May 2016 - 06:42 AM
Fiha,
i'll be really thankful if u can reply soon
#9 Mahdi1980
Mahdi1980
  • 182 posts
Posted 29 May 2016 - 09:01 AM
Fiha,
I want your hysys file to check your simulation.
Where is it? Please attach the file.
#10 Fiha
Fiha
  • 7 posts
Posted 29 May 2016 - 11:31 AM
I cant upload it
I dont know y
can i have ur email?
i can email it to u
#11 _Chemist_
_Chemist_
  • 10 posts
Posted 31 May 2016 - 02:38 PM
You should play continuously with number of tubes (I think you should increase a lot), length and diameter of the tubes. Moreover, you should define heat transfer material and its property. For every changing, look at outlet stream until you get maleic anhydride.
Edited by Hsnbrg, 31 May 2016 - 02:45 PM.
#12 titim
titim
  • 76 posts
Posted 01 June 2016 - 03:44 AM
hi; you can't upload .hsc file Fiha, save it as .XML and then you can upload it.
best regards
#13 Mahdi1980
Mahdi1980
  • 182 posts
Posted 05 June 2016 - 06:54 AM
Hi Fiha,
Did you solve your problem with no conversion?
If you already need help, please let me know.
I have simulated your process and reached the Maleic anhydride at the outlet of the PFR.
Mahdi
