Overall Heat Transfer Coefficient In Block Type Heat Exchanger
#1 S.R.Shah
S.R.Shah
  • 113 posts
Posted 05 June 2016 - 09:13 AM
Dear Sirs
Working on Designing reboiler and condenser with Graphite Block type heat exchanger
Block type heat exchanger is cross flow heat exchanger.Holes  are drilled for different fluids in a block.i.e. All heat phenomena can be considered tube side for both fluids.
My question is how  to calculate Overall Heat transfer coefficient for block type heat exchanger or by which formula.Formula for Shell and tube heat exchanger cannot be used.
I would like to correlate with Shell and tube heat exchanger by using heat transfer coefficients tube side for both sides.By this way one can use standard correlation for shell and tube heat exchangers
Request to give me either formula or better if excel spread sheet or literature
Thanks in Advance
Samir
Edited by S.R.Shah, 05 June 2016 - 03:42 PM.
  • 6,715 posts
Posted 05 June 2016 - 05:29 PM
Hi Samir ,
You may contact those guys to get data :
https://www.mersen.c...s-mersen_02.pdf
http://www.cepic.eu/...eat-exchangers/
http://www.louisvillegraphite.com/
Hope this helps
Edited by breizh, 05 June 2016 - 06:42 PM.
#3 S.R.Shah
S.R.Shah
  • 113 posts
Posted 05 June 2016 - 08:07 PM
Hi Breizh
Thanking you for useful information .But still not clear
For Shell and Tube Heat Exchanger
1/ UD =1/(hi *(Di/Do))+ 1/ho +1/(hsi *(Di/Do))+ 1/ho +( 2.3Do/2km)*Log(Do/Di)+1/hso
(Reference-D.Q. Kern)
I can take hi and ho considering both  tube side Heat transfer. And hso and hso,Thermal conductivity factor may be ignored due to high thermal conductivity
I am not clear about Do and Di for block heat exchanger
Please advise
Samir
#4 S.R.Shah
S.R.Shah
  • 113 posts
Posted 05 June 2016 - 09:21 PM
Hi Breizh
Got the reply .Assuming tube thickness and considering hole dia .as Tube ID ,we can corelate with shell and tube heat exchanger
Samir
#5 sharmaji_c
sharmaji_c
  • 3 posts
Posted 13 September 2016 - 02:20 AM
Samir Sir,
   can you share the calculation with us . . ??
#6 Dipankarc84
Dipankarc84
  • 51 posts
Posted 18 September 2016 - 05:49 AM
Hi Mr. Shah,
Thanks for sharing your problem and findings. The correlations for turbulent and laminar flow are different. The more popular correlation is for turbulent flow (e.g. Sieder Tate equation). However, perhaps the hole diameters in your graphite blocks will be much smaller than the typical tube IDs of 15.7, 19 or 25 mm. In that case, there is a chance that your flow regime might be laminar inside the holes. I am sure you have taken care of this. But just in case you missed it, would be worthwhile to check the Reynold's no. of the fluids.
Dipankar
