I want to analyze various dryers for wet cake, how can we reduce the time in ANFD(agitated nutch filter dryer).
also can you suggest better dryer than ANFD.
thanks
Posted 11 July 2016 - 06:51 AM
thanks
Posted 11 July 2016 - 10:43 PM Best Answer
chetan ,
different processes will require different technologies : Continuous vs batch .
For example : flash dryer & Fluid bed dryer / pallets dryer etc
Probably the industry you are working for will require different equipments , let say Pharmaceutical vs chemical based on the production rate .
For API I'm currently using Flash dryer and Fluid bed dryer , in the past I've been using Glatt dryer .
Let you use your favorite search engine to get more info .
Hope this is helping you a bit .
At What Temperature Does Water Evaporate When Drying A Solid ?Started by Guest_Checster_* , 30 Nov 2022 |
Fuel Gas Skid Gas DryingStarted by Guest_kengor10_* , 15 Feb 2022 |
Polymer Drying In Unisim R480Started by Guest_charb_* , 18 Jun 2021 |
Constant Rate Drying Equation During Flash/pneumatic DryingStarted by Guest_cheminst_* , 20 Jun 2019 |
Heat Recovery From Continuous Drying OvenStarted by Guest_Tong weng_* , 18 Jul 2018 |
