Folks,
Is there any a standard that specify the minimum pipe size that can go into pipe rack? I tried look into ASME B31.3 and API 5L but they did not mention anything related to it.
Posted 26 August 2016 - 11:08 AM
Folks,
Posted 26 August 2016 - 11:17 AM
This is usually a company policy. My experience has seen that somewhere at the 1.5-2 inch pipe is the minimum. It depends on how close cross members are for support.
Posted 26 August 2016 - 10:10 PM
As latexman said it's company policy. As per my experience for 6m between supports no less 2".
Posted 26 August 2016 - 11:09 PM
Mechanical strength of pipe reduces as diameter decreases. Small size pipes have greater tendency to sag when they are erected and additional supports / guides become necessary to keep them in position. It is, therefore, recommended to use 1.5” as minimum pipe size on pipe rack and sleepers. Only in exceptional cases (like very costly material of construction, etc.) lower sizes should be considered. However, short lines, which do not run on racks like piping vents, drains, miscellaneous connections for process pumps, sample connections etc can be of smaller pipe diameter.
Posted 27 August 2016 - 12:53 AM
ezralh,
In many engineering practices, the 2" pipe is the minimum pipe size can be put over a pipe rack...
Posted 27 August 2016 - 08:23 PM
thanks all for the info
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Pipe Entrance And Exit LossesStarted by Guest_katmar_* , 13 Nov 2024 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
