Moisture Removal
#1 ranjith kumar
ranjith kumar
  • 4 posts
Posted 27 June 2006 - 02:06 PM
hi
In my work place iam encountering a severe problem.The problem is that we are using DMF(Di Methyl Formamide) as a solvent in our process.But the moisture content in the solvent should not exceed 0.5%. When we are distilling the same we are getting DMF with more than 2 or 3%. so that we are unable to reuse that. resulting we are mixing it with effluent and going for fresh one in next batch .so that overheads are increasing and processing of effluent is becoming burden. Can anybody suggest the effective method to remove the traces of moisture .
shall i go for adsorption for the same thing. If so which one can i use
#2 kirangparihar
kirangparihar
  • 13 posts
Posted 27 June 2006 - 05:30 PM
QUOTE (ranjith kumar @ Jun 27 2006, 03:06 PM) <{POST_SNAPBACK}>
hi
Is there any problem with the distillation? I mean was distillation column designed for the specific purpose and now that you are not getting the output?
#3 pawan
pawan
  • 162 posts
Posted 28 June 2006 - 12:06 AM
Depending on ur quantity of DMF handled per day, U can opt for Molecular Sieve drying.
Thats the best solution for drying of organics for this level of moisture content.
#4 yergan
yergan
  • 9 posts
Posted 28 June 2006 - 02:04 AM
I dont fully understand your question but could you prevent the moisture entering, rather than removing it once it is in the solvent.
#5 venkateshgkademane
venkateshgkademane
Posted 05 September 2011 - 08:04 AM
what is the height of the distillation column and how much is vaccum
i have produced a lot of dmf moisture below 0.1 %
