hi dear friends,
I have observed a safety valve on pressure boost section of a diffuser in first stage of a two stage ejector. The shell side condensor of this ejector has vauum pressure. This safety valve isn't observed always on ejectors, even though the produced vacuum by those ejector may be the same. please explain me about the reason for including this safety valve.
thanks
Ejector
Started by ali, Jun 28 2006 02:14 AM
Posted 28 June 2006 - 02:14 AM
Posted 30 June 2006 - 02:48 PM
Dear Ali
Can you please be a little more clear? Can you describe the application?
Steam jet vacuum systems do not need a safety valve most of the times.
Some applications like steam jet vacuum systems for turbine surface condensers may have a safety valve installed at the intercondenser, but this is a specific case.
Paulo
Paulo
Posted 03 July 2006 - 12:39 PM
QUOTE (paulo @ Jun 30 2006, 02:48 PM) <{POST_SNAPBACK}>
Dear Ali
Paulo
Paulo
In the two stage ejector, on the end of diverging section of diffuser, I have observed the safety valve. the set pressure for ejector is 3.5 bar. It should be pointed out that the maximum allowable pressure for shell side of the intercondenser is also 3.5 bar.
thanks
Posted 05 July 2006 - 11:39 AM
Ali,
You have correctly observed that a safety valve (PSV) is not always associated with the intercondenser portion of a vacuum system. In your system, a PSV has been installed - presumably for good reason. IF you have a scenario where you can overpressure the equipment between the first and second stages (or anywhere else for that matter), then you need to circumvent this problem. Oftentimes, the solution is to add a PSV. I suspect that your predecessors foresaw a situation where the outlet path could be blocked. Again, guessing that the motive steam pressure is above the intercondenser design pressure of 3.5barg, they sought to protect the intercondenser from the scenario and therefore added a PSV. Assuming that the scenario is not totally ridiculous, so their approach is quite sensible.
Doug
Doug
Posted 06 October 2006 - 11:29 AM
Hi all,
I am trying to design an ejector where both my motive fluid and suction fluid are low temperature gases. Can any one please help me in the designing of it. Possibly can I get the relations or equations used in an excel file. My email id is malayanath-jeedi@utulsa.edu
Thanks.
Jeedi.
Thanks.
Jeedi.
![]() ![]() Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Eductor/ejectorStarted by Guest_Dorota86_* , 18 Jul 2023 |
Can Steam Ejector In Aspen Hysys Be Used In Aspen Plus?Started by Guest_efwefsef_* , 16 Mar 2017 |
Steam Air EjectorStarted by Guest_jordan1111_* , 31 Jan 2023 |
![]() Air EjectorStarted by Guest_jordan1111_* , 01 Nov 2022 |
