I have the following questions for sizing steam line:
what property package to select for sizing steam lines? Peng-Robinson or NSB Steam?
what is swage abrupt?
How to determine the number increments? Thanks
Posted 29 September 2016 - 10:17 AM
Posted 06 October 2016 - 03:44 PM
- For only steam case, use ASME Steam or NSB Steam Package, NSB is better specially near critical conditions.
- swage abrupt, a 180 degree swage rather than 45 degree.
- number of increments: must be enough to have for each increment dP < 10% of the inlet pressure, if dP exceed 10% then you need to increase the number of increments.
