Hello everyone,
I have a question about restriction orifices. I have to calculate the bore diameter of the orifice and to do this, I need to know the pressure drop across the orifice and the required flow rate (plus some other input data like density, viscosity and outer piping diameter).
I know the upstream pressure (60 psig) and I desire a water flow rate of 20 gpm through the orifice. What pressure drop should I take? The flow is delivered by a centrifugal pump and the orifice discharge line is connected to an atmospheric vessel (which is connected to the centrifugal pump). The purpose of the orifice is to have a continuous recirculation of water through the system.
Can I take the pressure drop = 60 psig?
Kind regards
Edited by Borpe_, 19 December 2016 - 04:05 PM.
