Edited by AhmadJAQF, 16 January 2017 - 10:01 AM.
Naphtha Hydrotreating Unit
Posted 16 January 2017 - 09:56 AM
Posted 16 January 2017 - 09:23 PM
What is RIT?
How can exothermic reaction become endothermic?
Posted 17 January 2017 - 01:43 AM
Posted 17 January 2017 - 04:32 AM
If Reactor Outlet Temperature is greater than Reactor Inlet Temperature, then the reaction IS exothermic.
If you still have doubts, post a sketch of the system with location of the Temperature Transmitters and Quench lines properly marked?
Posted 17 January 2017 - 05:10 PM
In your post " RIT is lower than reactor outlet temperature", so it is exothermic. Sulfur meets the spec. I don't see any problems with the catalyst or reactor.
Posted 18 January 2017 - 03:44 AM
I'm sorry I might mistyped the following sentence, What I meant is that the RIT is higher than the Outlet of the reactor, and sulfur for down stream units is within spec, delta P of the reactor is not in increasing trend, what I suspect is that the top layer of the catalyst is deactivated where the remaining is taking the load? does this make sense?
Posted 20 January 2017 - 09:18 PM
Hi Ahmad,
Perhaps there is very little reaction compared to other heat losses, and lower than original design (inlet concentration and feed flow). You mention the downstream sulphur concentration is ok, but how is the upstream or inlet sulphur concentration? Perhaps the feed to the hydrotreater is very low sulphur currently so there is not enough reaction to create temperature rise?
Keep in mind that there are often other hydrotreater reactions that could occur such as for nitrogen compounds.
Please let us all know what you find out.
Darren
Posted 22 January 2017 - 04:55 AM
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
