Estimating Liquid Mixture Viscosity
8 replies to this topic
#1 alex91ro
alex91ro
  • 4 posts
Posted 17 January 2017 - 03:47 PM
Is there any reliable correlation for estimating the viscosity of a blend? I read about Refutas, Kendal-Monroe, Chevron correlation and others but I have no idea which one give better results, I didn't find anything about a range of viscosities where they are efficient.
Thank you!
(PS: I hope you can understand my bad English)
Posted 17 January 2017 - 09:50 PM
When trying to estimate a liquid's viscosity in the past I always arrived at the unfortunate conclusion that there is no reliable method to estimate the viscosity of a pure liquid.  Only very approximate empirical rules were available.  Perhaps this has improved markedly in recent times, but I doubt it.  From a good and detailed explanation on the subject as well as sample calculations and results, go to:  http://www.owlnet.ri.../proj02/beckys/
Additionally, you can read the material found in Wikipedia: https://en.wikipedia...ends_of_liquids
#3 alex91ro
alex91ro
  • 4 posts
Posted 18 January 2017 - 02:32 AM
So the only solution is to make several blends and see what proportions give the desired viscosity?
#4 latexman
  • 1,812 posts
Posted 18 January 2017 - 07:55 AM
That will work.
#5 gegio1960
gegio1960
  • 518 posts
Posted 18 January 2017 - 10:41 AM
Alex, once acknowledged Art's valuable words I'd like to add my 2 cents of experience in the (limited) oil refining world.
Since you're asking about blending rules and their best ranges of application, you can use the following:
- refutas for residual fuel oils
- chevron correlation for ligher cuts (eg gasoils)
Good luck!
#6 Profe
Profe
  • 316 posts
Posted 18 January 2017 - 12:06 PM
Hi Alex
For your question, use procedure API 11A4.5: Liquid viscosity blending of hydrocarbon mixtures.
#7 alex91ro
alex91ro
  • 4 posts
Posted 18 January 2017 - 12:50 PM
gegio1960:
This equations are giving almost similar results, Chevron is always a little higher.  The problem is that Kendal-Monroe equation gives higher values of the mixture viscosity (2-3 x results of Refutas/Chevron) when there are big differences between the viscosities of the two liquids: Liquid 1 under 20 cst + Liquid 2 over 500 cst.  Which numbers are better?
@Profe
Do you have link? I can't find it.
Thank you all for your answers.
#8 gegio1960
gegio1960
  • 518 posts
Posted 18 January 2017 - 11:36 PM
Alex, with reference to #7
- This equations are giving almost similar results   YES, THAT'S GOOD
- The problem is that Kendal-Monroe equation gives higher values    DON'T USE IT
#9 Profe
Profe
  • 316 posts
Posted 19 January 2017 - 08:17 AM
Alex
Review a mesage that I send you about the  API procedure. Study it and review its aplication example
And attached I send an example of this method.
I Hope this will be useful.
Fausto.
