Design Pressure Of Reactor Jacket
design pressure reactor jacket
#1 modianurag
modianurag
  • 17 posts
Posted 01 March 2017 - 05:22 AM
Kindly suggest what would be the ideal Design pressure for a Reactor Jacket.
Does jacket fall under the category of Pressure vessel as condensate isn't held in the jacket for a long time.
Reactor is Mild Steel glass lined with Agitator.
We use steam for heating and water for cooling in jacket.
We want to optimize the heat transfer coefficient.
  • 6,715 posts
Posted 01 March 2017 - 05:59 AM
hi ,
let you consider the link attached, you should learn a lot from this company:
http://www.ddpsinc.c...&_hsmi=42795893
Be extremely careful with Thermal shock.  Sharing steam and cooling in the same jacket is not a good idea.  You need to make sure your jacket is free of water prior to introducing steam; otherwise there is a risk of water hammer and, for sure, the death of the glass.
#3 breizh
  • 6,715 posts
Posted 01 March 2017 - 10:21 PM
another good link :
http://www.gmmpfaudl...d-equipment.php
#4 CHEMENGR2811
CHEMENGR2811
  • 9 posts
Posted 02 March 2017 - 11:55 PM
Hai
Design pressure of reactor & its jacket is 6 kg/cm2.
Reactor jacket fall under pressure vessel design . ASME SecVIII Div1
If you want some more details search in GMM Pfaudler  / De-Dietrich, Swiss Glass coat websites.
