ive been trying to produce iron II oxide from using a 12 volt power supply, nail electrodes (which are magnetic and not galvenived so im assuming its iron), and sodium chloride as the ions to increase conductivity. the crude product from this electrolysis is a blue powder when in water but after filtration and drying it is a rust red color. ive tried testing the product by mixing aluminum powder with it and putting a magnesium strip in it and lighting it on fire to see if a thermite reaction would accure but no reaction. my thoughts are that the nails arent pure iron and contain other metals like copper. should i get a better source of iron if so where or should i use a better extraction technique to purify the iron oxide.
Making Iron Oxide By Electrolysis Using Iron Nails As Electrodes
Started by warlah, Mar 03 2017 12:33 PM
No replies to this topic
Posted 03 March 2017 - 12:33 PM
Electrolysis On HysysStarted by Guest_ciamba87_* , 01 Feb 2019 |
Pool Water Ionization Using Copper ElectrodesStarted by Guest_fragant-western_* , 29 Aug 2023 |
Desulfurization Of Natural Gas Using Zinc Oxide BedStarted by Guest_rgneengr_* , 18 Oct 2020 |
![]() ![]() Metal Oxide Process (Formaldehyde)Started by Guest_Has2riasat_* , 07 Nov 2022 |
I Need Help With Making A Compact Water CondenserStarted by Guest_Jimsonweed_* , 08 Sep 2022 |
