Is there a maximum pressure for saturated steam for use in a heat exchanger?
I want to heat a stream to 280 deg C, and saturated steam at 305 deg C is around 1300 psig. Is this pressure too high? Should superheated steam be used at this temperature and lower pressure?
If so, would it require using a different overall heat transfer coefficient?
