How is the conversion done? I need to convert 1000 Nm3/hr of air to Nm3/hr of nitrogen. What is the conversion factor? Is it dependent on the molecular weight?
Convert Nm3/hr Air To Nm3/hr Nitrogen
Posted 09 April 2017 - 09:56 PM
Posted 10 April 2017 - 05:23 AM
Nm3/h of Nitrogen = Nm3/h of Air*Sqroot (Mol wt of Air / Mol wt of Nitrogen)
See Graham's law in Wikipedia.
Ankur
Posted 10 April 2017 - 06:24 AM
The air composition in volumen is 79% nitrogen and 21% oxygen (approximately), then you have 790 Nm3/h.
Napo.
Posted 10 April 2017 - 06:31 AM
Princessme,
Napo.
I believe OP is asking for replacing Air with N2 for blanketing since this is "Tank Blanketing and Venting" sub-forum and not mole or volume percent of Nitrogen in Air.
Ankur
Posted 10 April 2017 - 06:53 AM
If this is the question, your answer is absolutely correct. Excuse me.
Napo.
Posted 10 April 2017 - 11:33 AM
Princess,
You should have learned in high school chemistry that any mole of ideal gas occupies the same volume at normal conditions.
Nitrogen Capacity Tankfarm During WinterStarted by Guest_jango_* , 03 Feb 2025 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() Most Feasible And Economically Friendly Nitrogen Supply For Tank BlankStarted by Guest_Godwin Anyimah_* , 27 Sep 2024 |
![]() Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
Nitrogen RequirementStarted by Guest_Ali4269278331_* , 05 Jun 2024 |
