Heat Of Dilution - Resulting Temperature
heat of dilution caustic soda naoh
7 replies to this topic
#1 kangas
kangas
  • 127 posts
Posted 11 April 2017 - 08:15 AM
Hello all,
I need some guidance in finding the resulting temperature for diluting a specific NaOH solution.
I have a stream of 23%w/w of NaOH with a flowrate of 0.042kg/s getting mixed with a stream of 0.445kg/s water, both streams being at 35oC. The resulting diluted solution has a mass fraction of 2%. How can I calculate the resulting temperature of this resulting stream?
I can work it out using a graph that I got from oxychem. However I would like to do it accurately using calcs. Can someone help me out how I can do it?
#2 MrShorty
MrShorty
  • 517 posts
Posted 12 April 2017 - 03:11 PM
Post #2 of this thread: https://www.cheresou...erature-change/describes a calculation procedure where the relative enthalpies of NaOH solutions is read off of a graph (from Perry's, I believe). The post mostly describes a relative simple heat/mass balance type calculation. In order to make it "accurate using calcs" one would need an accurate mathematical expression for the relative enthalpy of NaOH solutions as a function of temperature and concentration.
See if that helps get you started.
#3 breizh
  • 6,714 posts
Posted 13 April 2017 - 07:29 AM
hi ,
Go through the document.
#4 kangas
kangas
  • 127 posts
Posted 18 April 2017 - 11:04 AM
Thanks a lot Gents!
I managed to work this out!
#5 jadhavsn
jadhavsn
  • 11 posts
Posted 27 February 2018 - 01:12 PM
I want expression for relative enthalpy of NaOH as function of temperature and concentration.
Or can anyone provide Enthalpy concentration temperature data of NaOH in tabular form ???.
I have chart of enthalpy concentration but using chart is reduces accuracy
Edited by jadhavsn, 27 February 2018 - 01:14 PM.
#6 breizh
  • 6,714 posts
Posted 27 February 2018 - 06:08 PM
Consider these table and Graph.
Good luck,
#7 colby.cleavenger@merrick.c
Posted 02 June 2020 - 01:25 PM
Hello, I'm trying to do a similar calculation to figure out the final temperature when diluting a batch of water to 7.5% hydrogen peroxide using 25% hydrogen peroxide. Is there a similar document for H2O2 that relates heat of dilution to different concentrations and different temperatures?
#8 breizh
  • 6,714 posts
Posted 02 June 2020 - 06:47 PM
http://mae-nas.eng.u...L_TR_67_144.pdf
http://www.h2o2.com/...amic-Properties
Consider these resources.
Edited by breizh, 03 June 2020 - 07:49 PM.
