Stuffing Box Pressure Of Multistage Pump
#1 dilip
dilip
Posted 01 August 2006 - 08:44 AM
We have a mutistage pump with suction pressure 18 Kg/Cm2 & discharge pressure of 60 Kg/Cm2 & stuffing box pressure of 24Kg. We frequently have M/seal failures. Do these failures relate directly to stuffing box pressure? Is there any solution for this problem?
#2 tesser
tesser
  • 7 posts
Posted 04 August 2006 - 09:56 AM
QUOTE (dilip @ Aug 1 2006, 01:44 PM) <{POST_SNAPBACK}>
This is far too little information to determine what your problem is. Different designs of seal have different pressure ranges and certainly pressure is a factor to be taken into account when selecting a mechanical seal. but there are many other factors to be taken into account; shaft speed, product pumped etc.
Suggest that you consult your seal manufacturer giving him full duty conditions and product information
#3 Guest_machinery_*
Guest_machinery_*
  • guestGuests
Posted 05 August 2006 - 01:59 AM
dilip,
Mechanical seal design is have take account of the duty of pressure that usuallu the pump manufacturer do to select mechanical seal. I believe the high stuffing box pressure is not a root cause.
The possibility of mech seal failures are some because of misinstallation, mis-operation, misalignment of pump shaft and may be dirty of liquid buffer to the seal.
Have you check the above possibility??
machinery
