Gas Oil Ratio (Gor)
#1 DANA-IF
DANA-IF
  • 160 posts
Posted 15 May 2017 - 01:16 PM
Dear friends ;
I'm wondering if anyone could explain how the GOR of the well  is measured ?
REGARDS !
#2 shan
shan
  • 692 posts
Posted 16 May 2017 - 06:24 AM
Flash the well fluid at the standard conditions (0 psig, 60 F) to have the Gas Volume (SCF) and Oil Volume (BBL). Gas Oil Ratio (GOR) = Gas Volume/Oil Volume (SCF/BBL).
#3 DANA-IF
DANA-IF
  • 160 posts
Posted 16 May 2017 - 10:24 AM
Hello ;
I'm wondering what you mean with Flash the well fluid : passing it through a separator ?
REGARDS !
#4 serra
serra
  • 311 posts
Posted 17 May 2017 - 03:34 AM
dana,
for measuring GOR (gas-oil ratio) there are test separators,
google for  gas+oil+ratio+test+separator to find many results and discussions
with a software, there are two steps, 1) Reservoir Fluid Characterization 2) PVT Analysis
as suggested by shan, you can estimate GOR values (at some specified t, p) solving a flash operation (isothermal flash),
a separator (VL or VLL) allows to estimate vapor and liquid volumes at specified conditions.
#5 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 17 May 2017 - 12:09 PM   Best Answer
Dana,
Refer the link below for Gas-to-Oil ratio:
https://www.cheresou...z-beggs-method/
