Software For 2-component Oil Mixture Viscosity Calculation
Posted 07 August 2006 - 06:12 AM
I am working in a lube oil blending unit. I would like to know about the availability of a software for finding of viscosity of a mixture of two oils. It means by entering two companents (base oils) viscosity and compsition(%), we should get approximate viscosity of the mixture after blending those oils together according to the compsition given.
Anybody can help me please....
Alikutty
Kuwait.
Posted 10 August 2006 - 12:47 AM
I do not know whether any software is available for your purpose of blending lub oils, but I can give you some hints on which you can build your own software.
Please refer to Petroleum Refinery Engineering By Nelson, Figure 4-45 and Example 4-10. A method for blending lub oil bases stocks is given. Based on this, you can build your own software for blending lub oils.
Please note that Viscosity Index is not an additive property. If you are blending lub oils, you may have to take into consideration Viscosity Index also.
If you do not get the book or if you need any other clarifications, please write to me at pkrao43@yahoo.com
P.K.Rao
Posted 10 August 2006 - 01:44 AM
Thank u for ur information about my requirement of details about blending of oils. I wil try to search the details in that book and try to make it. I have got a website page having this calculation form, and i am trying to make a program for that..
we b page is : http://www.rohacell....e_oil_calc.html
thank u...
Posted 05 October 2006 - 10:59 AM
However, if you want you can contact Shell Marine Fuels, Exxon Mobil Marine Fuels or DNV PS who all produce fuel blend calculation software programs which will apply to any hydrocarbon mixture.
You may also find a sueful calculation that you can download from www.Steamesteem.com.
Posted 12 October 2006 - 10:27 PM
Have you got the software for viscosity blending? If not, please send your email. I have made a program in VB and will send it to you.
P.K.Rao
Posted 05 December 2006 - 03:00 AM
thank u...
Hi Alikutty,
I would like to develop a web based blending program for a university project similiar to the web based system you have developed, but i'm not familiar with blending formulas, and hope you could give me some help and advice. I hope you can help and look forward to your thoughts, comments, etc. I would like to thank you in advance for any help, advice and support.
Best Wishes,
Steven
Posted 07 February 2008 - 11:09 PM
P.K.Rao
Dear Mr. Rao:
Could you please share the your program also with me? It will be greatly appreciated.
Juan Garcia
Posted 08 February 2008 - 01:41 AM
1/u = w1/u1 + w2/u2, where:
u - viscosity of blend
w1, w2 - weight fractions of blending components
u1, u2 - dynamic viscosities of blending components
This formula yields rather good results for heat transfer calculations. And it is given for completely miscible components (hydrocarbons).
If you need much more precise calculations, I'd suggest you to build your own charts/correlations based on laboratory data.
Best regards,
Posted 08 February 2008 - 08:05 AM
The calculation can be downloaded by going first to this pdf file which contains the download link:
http://www.shell.com...nkercalc_pc.pdf
#10
Posted 14 April 2010 - 10:28 PM
<!--quoteo(post=8267:date=Oct 12 2006, 10:27 PM:name=P.K.Rao)--><div class='quotetop'>QUOTE (P.K.Rao @ Oct 12 2006, 10:27 PM) <a href="index.php?act=findpost&pid=8267"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Alikutty,
P.K.Rao<!--QuoteEnd--></div><!--QuoteEEnd-->
Dear Mr. Rao:
Juan Garcia
Dear Mr Rao,
Pls can I share the program. It really help me a lot.
My email: spila98@gmail.com
SH Foo
Malaysia
#11
Posted 14 April 2010 - 10:44 PM
I have tried to download the software but not avail. can you provide me other link.
Spila98@gmail.com
SH Foo
#12
Posted 14 April 2010 - 10:59 PM
Dear Mr. Rao:
Juan Garcia
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Add Kerosene To Component List On HysysStarted by Guest_Noran Shedid_* , 16 Nov 2019 |
Negative Sign In Newton's Law Of Viscosity?Started by Guest_Cheeky_* , 24 Oct 2024 |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
