Victor:
You ask for our opinion and I will gladly furnish mine. I’ve done this before and I recognize the installation as a potentially hazardous one and its serious design and implementation should be done at the highest level of safety and engineering.
Pilesar is absolutely correct. YOU are the purchasing client and it is up to you to specify to the transporter whether a pump should be supplied on the tanker truck. You should not be assuming anything on a project of this importance. Your basic Project Scope of Work should clearly denote that in detail. That is what a Scope of Work is supposed to do.
Who told you to “consider” a centrifugal pump? Was it your boss or an authoritative supervisor? What is meant by the term “consider”. If you are going to design and implement a nitric acid unloading system, your Scope of Work should already be prepared, reviewed, and approved. The type of pump should already be resolved and specified.
Please explain how you have arrived at the conclusion that a centrifugal pump will not “empty” the tanker truck - but a positive displacement one will. Is this something that is also being assumed? For your information, neither type of pump should be expected to fully deplete ALL the nitric acid out of the tanker truck and into the main storage tank. There will always be residual nitric acid left in the suction, pump casing, discharge lines, etc.. Are you familiar with the operation of a liquid transfer system?
Additionally, are you familiar with the characteristics of a positive displacement pump and its operation? What makes you think that there is a certain discharge pressure associated with the positive displacement pump? Are you aware that regardless of the type of pump you use, the discharge pressure (as measured at the pump’s outlet nozzle will always be the same? Pumps generate flow, not pressure.
What kind of PD pump are you referring to? Is it a gear, piston, or paddle type? Please be specific in your terms. Don’t use acronyms without identifying them. This leads to a lot of confusion and erroneous conclusions. For example, what do you mean by “FRT type”? Do you mean a Floating Roof Tank? Or do you mean “FRP” (Fiberglass Reinforced Plastic) tank? I would never use either of these types of tanks on nitric acid service.
There are a LOT of specification and safety issues involved with this proposed operation and I hope that you have had preliminary design, layout, and operating instructions already reviewed as well as a preliminary hazop. I think the best way for our expert members to give you their best help is for you to inform us fully on what you are proposing, why, and at what stage of engineering you presently find yourself at. Your experience in all this would also be of help to orient us all to your needs. Please respond with as much detail as you have available. Refer to the attached document.
Transporting_Nitric_Acid_in_Tanks.pdf 2.99MB
44 downloads
