Utility Plant Monitoring Spreadsheet
spreadsheet
#1 Takechi
Takechi
  • 43 posts
Posted 27 August 2017 - 02:03 AM
Dear all
Can anyone share utility plant monitoring spreadsheet to me?
Because I would like to improve performance monitoring system, If anyone have spreadsheet for monitoring utility plant which is cooling tower, demin. plant, compressed air, deaerator, and flare, please share to me.
Best regards,
Salapao
  • 6,677 posts
Posted 27 August 2017 - 02:20 AM
Salapao,
I believe you won't get much answer unless you supply your own work for us to review .
Basically we don't know what you are monitoring and which data are relevant for your plant , Did you set some KPIs ?
This kind of document should be easy to prepare with data collected on a daily basis or monthly basis .
If you use your favorite search engine and Youtube you will find some information on how to build a spreadsheet .
https://www4.eere.en...amo_steam_tool/
http://www.spiraxsar...-tutorials.aspx
https://www.gewater....dbook/index.jsp
Edited by breizh, 27 August 2017 - 03:12 AM.
#3 spchauhan12
spchauhan12
  • 43 posts
Posted 28 August 2017 - 02:20 AM
Dear Salapao ,
              For this you may approach to your sr. officers to oversee how is the existing format.
But if I would have been in your place, I would have prepare Utility performance monitoring system as below :
1) Tabulating - Sr. No., Utility Name, Type of Fluid, Service, Phase, Design Ranges & parameters contributing Performance
( Such as Temperature , Pressure, Ph, Hydrocarbon Content -For Flare Llines, SO2 /CO2 content for Flare etc.)
2)  Tabulating - Operating values ( such as Temp. , pressure etc.)
We can make final remark column - OK / Not OK & also corrective measures, if any.
Comments / suggestions, if any , are most welcome.
SPC
