Dear all,
Please suggest ,in flarenet whether we need to feed actual pipe length( actual pipe piece length) or length including fittings in length column.
Thanks,Stu
Posted 20 September 2017 - 11:07 PM
Dear all,
Thanks,Stu
Posted 21 September 2017 - 04:25 AM
Hi Stu
FlareNet allows you to do both. if you specify actual pipe length, you have to include fiitings from the program database. however, you can also input the equivalent length without fitting input also. both hydraulic results should be similar except, you activate the heat loss calculation on flare header.
Alerto
Edited by AlertO, 21 September 2017 - 04:28 AM.
Posted 21 September 2017 - 09:18 PM
Stu,
You can put any pipe fitting in Flarenet. But either you are not satisfy with backpressure result or you have another preference to determine equivalent length, that's no problem not to use it, just add that equivalent length into pipe length.
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Pipe Entrance And Exit LossesStarted by Guest_katmar_* , 13 Nov 2024 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
