Pd Pump Discharge Pressure Change
7 replies to this topic
#1 ma7ersi
ma7ersi
  • 9 posts
Posted 11 October 2017 - 03:24 AM
Dear Sir,
I want to retrofit an existing triplex high pressure pump (PD pump) for another use. However, the existing pump design pressure is 10000 psi and I need only 3000 psi for the new purpose.  Changing pump speed will only change the flowrate and not the discharge pressure.
I want to ask you, if i change the existing pump's motor with another motor with reduced power, can I achieve the required pressure or not.
If not, could someone help me and advise how to achieve this discharge pressure?
Best Reagrds,
#2 fallah
  • 5,019 posts
Posted 11 October 2017 - 04:53 AM
If for new purpose there is an existing system you are limited by system curve and conditions.
PD pumps are "Constant Flow" machines; hence if the flow rate is specified, draw the relevant pump curve (almost a vertical line in P-Q system) and find the intersection point of pump curve and system curve. This point dictates the pressure you will have in mentioned pump discharge.
#3 ma7ersi
ma7ersi
  • 9 posts
Posted 11 October 2017 - 05:38 AM
Thanks for your reply.
Please find attached here avilable vendor's data. The corresponding plunger diameter is 3/4". Thus, the pump discharge pressure is 10000 psi.
We want to use this pump for a new system and we want to limit pump discharge pressure to 3000 psi. Is this feasible or not?
#4 fallah
  • 5,019 posts
Posted 11 October 2017 - 06:05 AM
It's the maximum pressure to which the pump can mechanically achieve without any concern due to mechanical damage; and for new system, as I mentioned, you should find the working point by having the pump and system curves in hand...
#5 fallah
  • 5,019 posts
Posted 11 October 2017 - 06:06 AM
#6 ma7ersi
ma7ersi
  • 9 posts
Posted 11 October 2017 - 10:23 AM
Dear Fallah,
Thank you for your reply.
Best regards,
#7 Bobby Strain
Posted 11 October 2017 - 01:08 PM
One should always perform a vibration/pulsation analysis when using a positive displacement pump. And your case is no exception.
#8 farid.k
farid.k
  • 384 posts
Posted 17 October 2017 - 04:43 AM
May i know any issue if do nothing to the pump? Just use it. As discharge pressure will be according to discharge system. If required 3000psi, it will react accordingly
