Calculate Shell Side Heat Transfer Coefficient
heat exchanger
#1 DaleBrewster
DaleBrewster
  • 8 posts
Posted 26 November 2017 - 11:26 AM
Hello, I'm trying to come up with a method on excel to calculate the required surface area for a heat exchanger for a desired output temperature for a fluid (which can either be a gas or a liquid). I have a lot of familiarity with Heat Exchangers, especially  concentric shell and tube.
However, I'm fairly confused about how you calculate the heat transfer coefficient for the shell side fluid. I know that for the tube side, the overall flowrate is divided by the number of tubes to get the individual flowrate in each tube and that is used for calculating the internal heat transfer coefficient in the tubes, my main issue is how to calculate the heat transfer coefficient for the shell side as I don't know what equations to use.
I have done calculations in University that dealt with fluid flow over tube banks but I'm not sure how closely that relates to my problem.
Also, how much would the equations/ method change depending on if its a liquid or a gas such as steam or alcohol vapour. If someone could show me some example calculations for calculating the heat exchange between two fluids in a shell and tube heat exchanger with a bundle of straight tubes I would be very grateful.
I'm looking through Fundamentals of Heat and Mass transfer by Incropera and Dewitt, but in all examples heat transfer coefficient is given and not shown how to calculate for the heat exchangers.
I'd greatly appreciate if someone could tell me the method used and could supply me with some recommend texts with worked out examples and calculations.
Thank you
Dale Brewster
#2 srfish
srfish
  • 408 posts
Posted 26 November 2017 - 06:15 PM
Check out that old standard "Process Heat Transfer" by Kern.
Edited by srfish, 26 November 2017 - 06:19 PM.
#3 HJSN1994
HJSN1994
Posted 28 November 2017 - 03:38 AM
"Process Heat Transfer" by Kern is the best reference
#4 breizh
  • 6,715 posts
Posted 29 November 2017 - 11:32 PM
hi ,
a few documents to support .. Of course Kern is a must have !
hope this is helping
Edited by breizh, 30 November 2017 - 06:58 AM.
#5 DaleBrewster
DaleBrewster
  • 8 posts
Posted 05 December 2017 - 05:31 AM
Thank you guys very much for the help, it has cleared up a lot of things.
