Hello All,
I am doing project on simulation of Gas Turbine Compressor on HYSYS but I am unable to connect expander energy stream to compressor. I needed help to solve my problem.
Edited by qazihassan54, 28 February 2018 - 04:15 AM.
Posted 28 February 2018 - 03:52 AM
Hello All,
Posted 28 February 2018 - 06:35 AM
if the simulator can solve separately the two units (compressor and expander) there are not many reasons to create a link introducing the efficiency (polytropic, mechanical etc.) of the whole system,
for the case of a turbo compressor, don't forget that with wet gas / condensation (in expander) predicted values may be not accurate, see also this thread,
https://www.cheresou...gas-simulation/
usually I set (some preliminary) values for efficiency in both compressor and turbine...
Edited by serra, 28 February 2018 - 07:05 AM.
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
Centrifugal Compressor RecycleStarted by Guest_Lyne_* , 19 Aug 2025 |
