Compressor Differential Head Calculation
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 28 February 2018 - 08:18 AM
I want to convert compressor diff pressure into compressor differential head in meters. I have compressor inlet gas as hydrogen and methane . I have compressor capacity, speed and inlet density available also.
Can you please advice how to convert diff pressure into diff head.
Best Regards,
Chetan Chavan
#2 serra
serra
  • 311 posts
Posted 28 February 2018 - 09:49 AM
for liquids (assuming constant volume) it's easy head = (p2-p1)/(rho*g) -> dP*Vs/g
with compressors (volume not constant) head is normally defined as the work required (which can be espressed with different units as N-m/kg , ft-lbf/lbm etc.)
if you know inlet and outlet conditions it is possible to calculate the head directly,
or you can solve a compression stage and obtain the head as result.
Edited by serra, 28 February 2018 - 10:14 AM.
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 01 March 2018 - 01:10 AM
Dear sir,
Can you please tell me the equation to calculate it. Will it be polytropic process ?
Chetan Chavan
#4 serra
serra
  • 311 posts
Posted 01 March 2018 - 02:47 AM
you need the initial and final conditions then the actual work (head) = H(out) - H(in),
do not confuse polytropic head (the sum of isentropic heads) with the actual work,
some software defines a head (h1) as work = h1 * g where g is gravity and h1 has units of meters, feets etc. you can calculate h1 from actual work (head) and gravity,
yes, you can model the compressor with a generic polytropic model,
note that for efficiency = 1.0  polytropic -> isentropic then you can adopt a polytropic model in most cases...
there are many threads at cheresources discussing how to model a compression stage...
Edited by serra, 01 March 2018 - 02:49 AM.
