Flash Vessel Sizing
steam generator blowdown
#1 tizanidine
tizanidine
  • 14 posts
Posted 08 March 2018 - 11:31 AM
I need to size a steam drum/ flash vessel aimed to handle the blowdown from a steam generator.
The inlet at the vessel is tangential to exploit the "cyclonic" effect for the water.
I would like to know the needed equations to size the "cyclone/drum"
Thank you in advance! :)
  • 1,552 posts
Posted 08 March 2018 - 12:35 PM
Consider a pre-engineered flash tank for steam. The overall cost may be cheaper since the engineering is in the price and the sizing has been tested in multiple industrial installations. See for example: http://www.spiraxsar...Information.pdf
You can design steam flash tanks yourself, of course, but I have always calculated much larger tanks when using standard vapor-liquid separator guidelines such as found in Chapter 7 of the GPSA Engineering Data Book. I think the separation criteria is different for steam than for process streams since you will always have condensate in the saturated steam lines which have traps anyway. So what if you get wet steam out the top of the tank? The economics for larger 'normal sized' flash tanks may not justify them. I have tried to back-calculate how the expert steam specialists get such small diameters for their steam flash tanks, but there must be some engineering principle I am not taking into consideration.
If you have tangential inlet in your design, expect wall erosion and include enough material in the target area to account for severe wear.
#3 breizh
  • 6,714 posts
Posted 08 March 2018 - 06:34 PM
hi,
http://www.pennseparator.com/fssel.htm
Consider this resource .
#4 Top_Gun
Top_Gun
  • 7 posts
Posted 10 April 2023 - 04:39 PM
Hi Pilesar,
I realize that this is an old post, but I was searching the site for steam flash tank sizing information, and I found your post.  I am currently troubleshooting a steam flash tank, and I too have noticed the discrepancy for the required diameter between the common methods (e.g., API 12J) and the results of steam/condensate flash tank manufacturers.
In my mind, the difference must lie in the K-factor (as in, Va = K * [(rhoL-rhoG)/rhoG]^0.5 ).  Although many references commonly refer to the K-factor as a constant, it is really a velocity term with 0.35 ft/s or 0.107 m/s as "typical" values.  The assumed maximum allowable velocity for a droplet to settle is then modified by the density term.
This in turn, must be fundamentally related to the droplet size assumed in standard oil/gas processing references.  Since organics typically have a much lower surface tension than water, they make smaller (finer) droplets; thus requiring a lower maximum allowable velocity for them to gravity settle.  The problem is, I cannot find the stated K-factor for steam/condensate systems.  It must be a much higher number.
For the unit I'm currently troubleshooting, it was apparently designed with a vapor velocity of 30 ft/s in the flash tank (i.e., not the vent line).  This seems ridiculously high to me, but the unit was designed by a well-known supplier.
Have you been able to find any further references to an acceptable K-factor for steam/condensate systems?
#5 Bobby Strain
Posted 10 April 2023 - 06:22 PM
 It's difficult to find sizing procedures for tangential inlet separators. Can you provide information on your vessel and operating conditions? I once had a procedure, but don't know if it is still around.
Edited by Bobby Strain, 10 April 2023 - 06:27 PM.
#6 Pilesar
  • 1,552 posts
Posted 10 April 2023 - 07:26 PM
I have no additional design information and also found troubleshooting steam separator problems difficult. I suspect the surface tension you mentioned does play a role such that the internals purposely aggregate the condensate to larger drops through direction changes and impact surfaces. Knocking out the large droplets of condensate would mean success in this service. You can review vendor catalogs which give separator diameter and steam capacity to back-calculate a K-factor if you think it useful. I had little confidence in measured flows around the steam separators I dealt with and therefore relied on a generous safety factor.
#7 breizh
  • 6,714 posts
Posted 10 April 2023 - 08:45 PM
You may consult vendors to size your equipment,
another reference:
https://content.gest...8e6227389e4438d
sizing information:
BN-EG-UE109 Guide for Vessel Sizing (red-bag.com)
