Parallel Pump Operation
#1 Deep24
Deep24
  • 8 posts
Posted 07 May 2018 - 07:19 AM
In my plant I have two pumps for pumping 300 Ton of water per hour. Pump rated flow is 300 Ton per hour. One pump kept as standby while other is running.
Now I need a continuous flow requirement of 400 Ton per hour for that both pumps need kept running.
I need a third pump.
Should I install it of same size & capacity as existing pump or lesser capacity?
Deep
#2 rikakose
rikakose
  • 80 posts
Posted 07 May 2018 - 09:54 AM
Both of them should work. It is up to the line-up of the pumps, pipes, controls, parameters of pumps.
#3 Bobby Strain
Posted 07 May 2018 - 11:49 AM
It's not quite that simple. So the advice you got is misleading.
#4 fallah
  • 5,019 posts
Posted 07 May 2018 - 12:58 PM
Deep,
It absolutely depends on the pumps and system curves...
#5 villivord
villivord
  • 13 posts
Posted 07 May 2018 - 01:43 PM
You'll need to evaluate the whole system (design conditions, ...) in which the pumps are operating to guarantee a safe transition to this new flow rate.
#6 Zauberberg
Zauberberg
  • 2,728 posts
Posted 07 May 2018 - 01:46 PM
Read these two articles from Joe Evans. Great article explaining the subject in simple terms.
http://www.pumped101...x.html#parallel
