Software For Calculating Flow Through A Pipe
15 replies to this topic
#1 Deep24
Deep24
  • 8 posts
Posted 07 May 2018 - 07:25 AM
I need a software or excel sheet for calculating maximum flow through a pipe. Line upstream & downstream pressure are available.
Also for a certain upstream pressure & flow, what will be the maximum pressure drop through a pipe.
Pls help.
Deep
#2 Technical Bard
Technical Bard
  • 407 posts
Posted 07 May 2018 - 01:00 PM
This is a relatively easy thing to build yourself from textbook equations.
#3 Bobby Strain
Posted 07 May 2018 - 02:06 PM
But there are many on this site. Also, you can look for commercial stuff for a good value. Try Steve Hall and Harvey Wilson at Katmar.
#4 Art Montemayor
Posted 07 May 2018 - 03:48 PM
Bobby is precisely right.
I cannot recommend Harvey Wilson's fluid flow software enough.  You can't beat the price he charges for the quality his software produces.  I've used it many times with good results.
It is called Aioflo Pipeflow Calculator and you can buy it at:
https://www.katmarso...x.html#products
#5 v7788999
v7788999
Posted 02 August 2018 - 12:47 AM
Try "Refining online" has a little program for unit convert, steam property and line sizing.
#6 Jorge_RZ
Jorge_RZ
  • 8 posts
Posted 02 August 2018 - 02:58 PM
For simple piping calculations, there's many websites available for free.
For more reliable results, I'd also recommend Aioflo like Bobby and Art.
More more complex piping systems, we use Korf Hydraulics by Korf Technology Ltd. I strongly recommend it if you do this kind of calculations regularly.
http://www.korf.co.uk/
You can build entire piping systems with valves and fittings, including compressors, pumps, control valves, etc.
Hope it helps.
Jorge
#7 Che#pet
Che#pet
  • 5 posts
Posted 22 May 2019 - 11:15 AM
You can use ASPEN HYSYS also for this purpose. When you specify the pipe inlet pressure, inlet temperature, pipe diameter, pipe length and pipe outlet pressure, HYSYS will back calculate the flow which will be the maximum flow possible for the available system differential pressure.
#8 Clezike04
Clezike04
Posted 16 October 2019 - 10:54 AM
Pipephase would do all of what you ask.
#9 Yasserkassem
Yasserkassem
  • 22 posts
Posted 30 October 2019 - 08:50 AM
Hello
you will find some suitable excel sheets in the next post
https://www.cheresou...s-calculations/
best regards
#10 ieseberri
ieseberri
  • 6 posts
Posted 29 May 2020 - 07:50 AM
Hello!
If you are looking for an online free flow rate calculator, visit this website :
https://instrumentat...alculator.html#
You are going to be able to download the results calculation for free!
Enjoy!
#11 breizh
  • 7,037 posts
Posted 28 September 2024 - 06:44 AM
Refrain to use this forum for business purpose.
I will delete your post.
#12 SamThaGangsta
SamThaGangsta
Posted 18 December 2024 - 04:58 PM
I actually just built a model from scratch, very easy to do. Although, I did have a starting place from a pump curve as the flow was between a vacuum pump, condenser, and dryer. Darcy-Weinbach,  simplified Bernoulli, or other will give you a very good estimate for both flow rate and subsequent pressure drop and vice versa. The model works pretty well with what is observed in the process as well.
Density of Air Viscosity of Air Density of Steam Viscosity of Steam Percent Air Percent Steam Density of Mixture Viscosity of Mixture Length Diameter Roughness Flow Rate Velocity Re Friction Factor Pressure Losses Major Losses Minor Losses Total Losses P2
Used these variables. Derived from equations, process data, ANSI, Crane's flow manual, and Perry's. Once you have these values or the equations to solve for these values it should be plug and chug.
#13 Hamidpalan
Hamidpalan
  • 4 posts
Posted 25 December 2024 - 07:06 AM
You can use Simcenter Flomaster software, similar to Hysys. Reliable and accurate. I can help if you need.
Edited by Hamidpalan, 25 December 2024 - 07:19 AM.
#14 Dacs
Dacs
  • 457 posts
Posted 05 January 2025 - 02:10 AM
I know, late in the game but...
TL;DR: No.
Longer answer: NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
There's a reason why Hysys, Flarenet and Hysys Hydraulics exist. Piping hydraulics in Hysys is acceptable for general use, but will behave very poorly in choked flow conditions.
#15 Hamidpalan
Hamidpalan
  • 4 posts
Posted 05 January 2025 - 09:53 AM
You can use Flowmaster for steady state and transit modeling of chocked flow, water hammer,... in pipes.
#16 cloudyangel
cloudyangel
  • 4 posts
Posted 15 January 2026 - 09:18 AM
It is a common question in the chemical engineering.  There is one ios app (cryongeics pro) has a pressure drop module may could solve the problem.
Attached File  Simulator Screenshot - iPad Pro 13-inch (M5) - 2026-01-15 at 22.24.06.png   901.88KB   1 downloads
