Molecular Sieve Adsorption Dryer Trouble Shooting
14 replies to this topic
#1 Root
Root
  • 293 posts
Posted 01 July 2018 - 10:13 PM
Hi All,
Our DHU is designed on TSA based and we are facing problem in moisture break through. here is some information for your consideration and feedback on this topic.
MOL Sieve type: 4 A (UOP)
Bed: 2+1 (one on regeneration +one adsorption+ one standby)
Feed gas flow: 98 MMSCFD
Regeneration gas flow: 10 MMSCFD (design)
Mole Sieve height: 5.79m (4A mol sieves loaded in beds).
Liquid recovery in scrubber: very low
Gas inlet temperature: 68 0F
Feed gas is cooled with propane chiller before entering in inlet scrubber.
When regenerating on low pressure it work fine for three days and then start moisture breakthrough on normal (high pressure regeneration mode). I attached a DCS screen shot that is indicating bed inlet and outlet temp difference is almost 40 0F but outlet temperature start decreasing after 40-45 minutes. What i understand water is not fully removed because outlet temperature remain high for longer time.
Forum experts i need your advice how to trouble shoot this problem.
Root
Edited by Root, 01 July 2018 - 10:14 PM.
#2 Bobby Strain
Posted 02 July 2018 - 11:40 AM
You probably have liquid carryover that has fouled the sieves. You need a proper filter-separator upstream of the dryers. The only cure is to install the filter-separator and replace the sieves.
#3 Root
Root
  • 293 posts
Posted 02 July 2018 - 09:56 PM
Hi Bobby,
Mol Sieve dryer inlet we have coalescer filter 10micron size. hence no liquid carryover. feed composition also does not have olefins , no sulphur as well.
Toor
#4 Art Montemayor
Posted 03 July 2018 - 08:21 PM
Root:
What is a "DHU"?  I need this identity to edit the title of this thread.  Otherwise, it won't contribute anything to our Search Engine.
#5 Bobby Strain
Posted 03 July 2018 - 08:30 PM
Give us the history of the sieves. And what is the gas being processed along with conditions. Unless the sieves are old, it still can be due to liquid carryover if the filter separator is damaged, or not draining.
#6 Root
Root
  • 293 posts
Posted 03 July 2018 - 09:47 PM
Sir,
Dehydration unit (DHU).
LPG recovery plant started this year march. Mol sieve dryers are filled with UOP 4A type moles. inlet of Mol sieve dryers are cool down to 68F in chiller, then gas flow to inlet scrubber and then to coalescer filter and then to mol sieve dryers.
Dryer fill up drawing is attached for consideration.
Root
#7 Bobby Strain
Posted 03 July 2018 - 11:09 PM
I assume that all three dryers show the same behavior. Is that true? If so, it's likely due to some contaminant in the gas. You will eventually have to replace the beds sooner than you planned.
#8 Root
Root
  • 293 posts
Posted 04 July 2018 - 01:01 AM
Yes all three bed behave similarly, Inlet gas C6+ is .009 and dry gas also have same as inlet. once again i repeat there is no pressure drop during regeneration time. the change is only in temperature. additionally no valve passing.
when we regenerate at low pressure then bed is working very well and dew point goto below -98 F.
Root
#9 benabed
benabed
  • 59 posts
Posted 04 July 2018 - 04:14 AM
Look likes you have channeling problem due water carry over from upstream separator
#10 Bobby Strain
Posted 04 July 2018 - 09:17 AM
What do you mean by "the change is only in temperature"? What is the normal operating pressure? What is the regeneration gas? What is the low pressure regeneration pressure? We need lots more information. Including gas composition and source. It still looks to be some contaminant. What are the cycle times? When did this begin to happen? Have you consulted with UOP?
#11 Root
Root
  • 293 posts
Posted 04 July 2018 - 09:33 PM
Here is more information,
Gas is coming from separator, you can read my 1st post for more information.
Adsorption time: 8 hrs
Heating time : 5 hrs
Cooling Time: 3 hrs
Hold time: 5 minutes
Normal operating pressure: 1050 psig
Regeneration normal operating pressure: 1050 psig
In case of low pressure regeneration then pressure: 510 psig.
Feed composition: (mole%)
C1:84.398
C2:7.695
C3:3.283
iC4:0.298
nC4:0.444
iC5:0.061
nC5:0.039
C6+:0.014
N2;1.002
CO2;1.428
Inquiry has sent to uop but waiting for their reply.
Root
#12 Root
Root
  • 293 posts
Posted 04 July 2018 - 09:35 PM
No water carryover, keep focus on my input information.
#13 Bobby Strain
Posted 04 July 2018 - 10:10 PM
Do you recycle cooled regeneration gas to dryer feed chiller? If there are other similar operations within the field, you should talk with them.
#14 Root
Root
  • 293 posts
Posted 04 July 2018 - 10:19 PM
Regeneration gas after cooler and regeneration scrubber going back to feed inlet line, the aim is max hydrocarbon recovery.
Root
#15 Bobby Strain
Posted 04 July 2018 - 11:05 PM
So, if you have some strange contaminant then it will build concentration via the regenation gas recycle. Must be something unusual, because I haven't heard of problems that you are experiencing. UOP should have some suggestions for you. And, UOP should check the sizing of your dryers. But at this early operation the sieves should be quite active.
