Pump Npsh Ample?!
#1 Poet
Poet
  • 11 posts
Posted 04 July 2018 - 12:12 AM
Hello.
I'm working refinery revamping PJ.
I received existing pump datasheets from Company and I found a term "AMPLE".
Some pump datasheets specifies NPSH available as "AMPLE" instead of certain value.
I would like to know exact meaning of AMPLE and how should I understand this.
Thanks a lot.
#2 fallah
  • 5,019 posts
Posted 04 July 2018 - 02:25 AM
Poet,
It means: "More Than Enough"...hence wherever the NPSHA is specified as "Ample", doesn't need to be specified with a value and the pump's NPSHR would be adequately lower than the NPSHA...
#3 Bobby Strain
Posted 04 July 2018 - 09:19 AM
You need to do some work!
#4 Chemitofreak
Chemitofreak
  • 292 posts
Posted 05 July 2018 - 02:43 AM
I have seen ample specified in the datasheets for Vertical and Submersible Pump pumping sub cooled liquid.
These pumps can have high NPSHA hence at times AMPLE is specified in the datasheet.
Edited by Chemitofreak, 27 July 2018 - 07:33 AM.
