Can you help me figure out the difference between these two types of foam? EVA/POE/EPDM and SCE45 Neoprene/EPDM/SBR?
The foam is being used to seal a bottle with a screw on lid to keep it water tight
Edited by Jason73, 02 August 2018 - 02:11 PM.
Posted 01 August 2018 - 02:23 PM
Posted 01 August 2018 - 07:09 PM
Did you try Google?
Posted 02 August 2018 - 02:13 PM
Yes. I found descriptions for both but need to know if one is better than the other for my application which is a water tight plastic jar where another plastic lid is screwed onto it. Think of a peanut butter jar on steroids
What Are The Differences Between Ph,orp & Chlorine Dioxide AnalyseStarted by Guest_Radha Krishnan Siva Kumar_* , 01 Apr 2024 |
Differences Between Demineralized Water And Boiler Feed WaterStarted by Guest_Vegeta_* , 09 Aug 2022 |
Similarities And Differences Of Liquids And PowdersStarted by Guest_SamerIssa_* , 06 Jan 2019 |
What Is The Differences Betwen Sulfinol-X And Sulfinol-M?Started by Guest_nuel92_* , 27 Jul 2015 |
![]() Differences Between Density At 15 C (In Air) And Density At 15 C (In VStarted by Guest_Tolinorton_* , 13 Aug 2014 |
