Shut-Off Pressure Of On /off Valve
#1 Abdullah_28
Abdullah_28
  • 26 posts
Posted 26 September 2018 - 03:27 AM
Dear
Iam working on small project where I need to change ON/OFF valves on the suction line of pumps ( to have same rating of discharge line) in different units of refinery .
Question:
As per I know the Shut of pressure (closure delta P -used for actuator sizing)  is specified as following :
                     Shut of pressure=Max Upstream pressure- Downstream Pressure
In case the suction line of pump, I used the following:
                      Shut of pressure=Max Suc. pressure (Set press.) - Downstream Pressure  (0 brag)
However ,one friend told me if there is a leak in check valve, there will be  back pressure on the downstream of suction block valve. so the worst case is to specify two Shut of pressures  as following:
               Forward Shut of pressure:
               Reverse Shut of pressure:
               Shut of pressure=Normal Suc. pressure  - Discharge pressure Pressure
Is this make sense?
​I need your Valuable input on this subject.
Thanks a lot
Edited by Abdullah_28, 26 September 2018 - 03:33 AM.
#2 fallah
  • 5,019 posts
Posted 26 September 2018 - 07:20 AM
Dear
Question:
Is this make sense?
 to
Abdullah,
If the pump is conducting the fluid to a pressurized system and the relevant check valve is susceptible to leak, the reverse flow can be occurred in pump trip case and the suction on/off valve (if existed) can be subject to discharge pressure at downstream while there is normal suction pressure at upstream.
#3 Abdullah_28
Abdullah_28
  • 26 posts
Posted 26 September 2018 - 08:00 AM
Dear Fallah,
Does this mean  we have to consider both cases in data sheet ? (  Forward and Reverse)
#4 fallah
  • 5,019 posts
Posted 26 September 2018 - 08:42 AM
Abdullah,
You haven't to do so; you can specify the worst case and reflect it to the valve data sheet...
If you have a problem to specify the worst case you can reflect both cases in data sheet...
