Hello. Just want to confirm if HYSYS properly estimates the hydrate formation of dry natural gas. In my simulation, the hydrate formation temp of the dry feed gas is at 22.81degC. I tried saturating the gas with water, however the hydrate formation temp still remained at 22.81degC. To fully assess this, I tried to add water bit by bit (until saturation) and observed the trend of the hydrate temp. I noticed that with a bit of water, the hydrate temp drops to negative (at the same pressure). As I add more water, the hydrate temp gradually rises until it reaches 22.81degC at a point before saturation and it plateaus from there.
Is it HYSYS fault? Or do any of you happen to know how to estimate hydrate temp of dry gas?
