I WOULD BE SO PLEASES IF ANY ONE SEND ME INFORMATION 16 STAGE DOUBLE CASING PUMP WUC
Flowserve Multi Stage Vertical Vs6 Pump Information
Started by Rahimzadeh, Oct 04 2018 01:58 PM
Posted 04 October 2018 - 01:58 PM
Posted 04 October 2018 - 07:15 PM
For the sake of indexing the topic, please tell us what is a pump Wuc.
Posted 05 October 2018 - 03:02 AM
Dear Art:
Flowserve named multi stage vertical double casing (CAN) type pump VS6
Posted 11 October 2018 - 11:32 PM
Normally that pump is used when the NPSHa of the system is low. Normally those liquid easily to vaporize i.e C2=, C3=, LPG services will used that.
The barrel will be buried underground and you gain some more static head that can improve the NPSHa.
![]() Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
