Edited by farid.k, 11 October 2018 - 11:16 PM.
Cryogenic Pipelines
Started by farid.k, Oct 11 2018 11:13 PM
Posted 11 October 2018 - 11:13 PM
I plan to transfer LNG - 104 oC. The challenge is piping is about 6km and insulation has to be thick (150mm). still insulation vendor cannot guaranteed that it can above - 100 oC at the end of destination or the receiver . Probably - 95 oC something and that temperature is cannot be accepted. Should i consider new chiller before the receiver? Any other experience on the long pipeline for liquid cryogenic transfer? Any suggestions for the insulation? Currently i used the best insulation material which is crogel that better compared to foam glass.
Posted 12 October 2018 - 04:01 AM
If the budget allows, vacuum insulated pipe?
Posted 12 October 2018 - 04:54 AM
Is it ok for 6km piping? What if vacuum system leak? Any place have practice this?
Posted 12 October 2018 - 11:16 PM
Hi Farid,
Let you try to get a copy of this book written by Alireza Bahadori .
Thermal insulation handbook for the Oil , Gas and Petrochemicals Industries ,
dedicated chapter about LNG :Cryogenic insulation system for LNG Industries
It's worth to have a look together with the use of your favorite engine .
Hope this is helping you.
Flow Assurance Simulation - Transmission PipelinesStarted by Guest_Jeffs_* , 15 May 2024 |
Cryogenic Distillation To Produce Nitrogen GasStarted by Guest_Eng4324_* , 04 Mar 2024 |
Quantitative Risk Assessment Of Onshore Crude Oil PipelinesStarted by Guest_Mansi_* , 14 Feb 2024 |
![]() Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
![]() Converging Cryogenic Air Separation In HysysStarted by Guest_rgc1994_* , 22 Mar 2017 |
