is it possible for the nozzle schedule to be different than pipe schedule.
for eg if nozzle schedule is 12 inch 40 sch and pipe schedule is 12 inch 20 schedule..will this work??
thnks,
Posted 21 November 2018 - 02:49 PM
thnks,
Posted 21 November 2018 - 09:24 PM
It can. This is usually a consequence of one side being "overdesigned", but there are cases where the nozzle on the equipment doesn't need the same wall thickness as the pipe because the nozzle is short and is reinforced by the vessel/exchanger shell. You need to recognize that there may be a flow restriction or turbulence making situation when this happens (because the IDs are not the same). This can be dangerous if the fluid can wear the material (for instance if there is sand in the fluid).
Posted 24 November 2018 - 12:38 AM
How about nozzle flange?
You should use the design pressure as a basis, then check the nozzle flange rating and associated pipe thickness to cover the design pressure. In this way, if both would be within the range no matter one of them is stronger than another.
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
