Edited by TX-2, 19 December 2018 - 01:11 AM.
Posted 17 December 2018 - 01:48 PM
Posted 17 December 2018 - 03:37 PM
It's difficult to follow your simulation PFD. Maybe you can fix it up a bit. Maybe show two views. And remove all the unnecessary information.
Posted 17 December 2018 - 04:30 PM
You should add a dummy stream attached on TEE-100 because the flow summary of Streams 16, 100, 101 and 93 is not necessarily equal to flow of Stream 20.
Posted 19 December 2018 - 01:17 AM
Thanks everyone. As Bobby suggested, I have cleaned up my HYSYS simulation to show only the relevant information and added a hand drawing showing the configuration. What I am trying to determine is that is it possible to use the propane refrigerant from the cycle to eventually cool itself in the Trim Cooler, I have highlighted the line in yellow in my hand drawing. I feel that refrigerant/cooling duty to the Water Cooler needs to be supplied from outside this cycle not from the cycle. I will appreciate your help with this. Please let me know if you need additional information.
Edited by TX-2, 19 December 2018 - 03:52 AM.
Posted 19 December 2018 - 11:02 AM
I believe that you should first remove the water loop exchangers and replace them with propane heater/cooler until you get a solution. Furthermore, I would move the propane recycle controller to the compressor discharge. You must add a controller or multiple controllers to adjust propane flow to various loads. Once you accomplish this, then you can replace the heater/cooler with exchangers.
Posted 21 December 2018 - 09:20 AM
Look up a flowsheet for a two stage refrigeration compressor with economizer. You must have an external cooling method (air or water) to reject the heat from the system.
Posted 25 December 2018 - 04:31 PM
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Propane Loss From Sphere TankStarted by Guest_rasprocess2026_* , 04 Nov 2024 |
![]() Air-Cooler Heat Exchanger - Unit Vs BayStarted by Guest_pymorty_* , 19 Dec 2023 |
Subcooling And Vapor Refrigerant CondensationStarted by Guest_panoska_* , 19 Nov 2023 |
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
