Centrifugal Pump Design Assumptions.
8 replies to this topic
#1 SSU_PE
SSU_PE
  • 11 posts
Posted 22 December 2018 - 03:30 AM
Could anyone please explain the basis of assumption for following parameters in pump design,
1. Pump speed.
2. Pump efficiency.
Thanks,
Subodh Ubhare.
#2 thorium90
thorium90
  • 1,073 posts
Posted 22 December 2018 - 09:14 AM
As in sizing a pump or designing a pump?
#3 SSU_PE
SSU_PE
  • 11 posts
Posted 30 December 2018 - 01:23 AM
Dear thorium90
as in sizing of CF pump, for pump efficiency & impeller rotation speed.
#4 breizh
  • 6,715 posts
Posted 30 December 2018 - 04:18 AM
Consider the resource attached.
Good luck.
#5 Chemitofreak
Chemitofreak
  • 292 posts
Posted 31 December 2018 - 02:35 AM
1. Pump speed.
2. Pump efficiency.
Thanks,
Subodh Ubhare.
Hi Subodh,
I guess you need to get in touch with a Rotating Engineer in your company for these values. He can provide you an approx value based on Archive data or he can get in touch with a vendor who can provide the same.
#6 gegio1960
gegio1960
  • 518 posts
Posted 01 January 2019 - 05:39 AM
my 2 cents from the young years as process engineer in the refining setor:
- assume 3500 rpm
- estimate efficiency according to the attached graph (based on stats)
- check/revise on the base of catalog selection and, finally, vendor data
good luck!
#7 fallah
  • 5,019 posts
Posted 01 January 2019 - 07:24 AM
1. Pump speed.
2. Pump efficiency.
These are the pump parameters are utilizing/specifying by the design division of the pumps manufacturers; hence to get a real sense about the typical values of them you can refer to the relevant vendors catalogs...
#8 breizh
  • 6,715 posts
Posted 01 January 2019 - 07:28 AM
To add to my previous email :
http://www.mcnallyin...-html/7-03.html
hope this is helping  you.
#9 thorium90
thorium90
  • 1,073 posts
Posted 01 January 2019 - 07:54 AM
- assume 3500 rpm
good luck!
Considering "Subodh Ubhare" is in Mumbai and the electrical frequency is 50Hz there, 3000rpm should be used for motor speed. 3600rpm is for 60Hz countries and the slight reduction is from slip.
