Scrubber Solution
scrubber solution selection
#1 New Chemicals
New Chemicals
  • 4 posts
Posted 23 January 2019 - 09:05 AM
I want to design scrubber column for mixture of butyl acrylate and vinyl acetate monomer vapor. Which solution should i use to scrub the vapours
Thanks in advance
#2 latexman
  • 1,809 posts
Posted 23 January 2019 - 11:17 AM
I've seen Triethylenetetramine (TETA) and caustic solutions used.  TETA where the hazardous waste is/can be incinerated.  Caustic where there is available waste water treatment capacity.
#3 New Chemicals
New Chemicals
  • 4 posts
Posted 23 January 2019 - 03:39 PM
Thank you very much latexman. One more question? What about the concentration?
How can I calculate the concentration. Could you suggest me a starting point.
Is it feasable to use 1 mof water + 50-80 L of caustic + 40-60 L of TETA solution.
Edited by New Chemicals, 24 January 2019 - 01:56 PM.
#4 breizh
  • 6,715 posts
Posted 23 January 2019 - 06:39 PM
I've attached a design of scrubber for other types of monomers ( Acrylic esters) , the concentration of caustic is about 10 % w/w.
To me the issue is what to do with the spent liquor , destruction is quite expensive .
Hope this helping you .
#5 New Chemicals
New Chemicals
  • 4 posts
Posted 24 January 2019 - 02:04 AM
Breizh:
Thanks for your reply.
#6 latexman
  • 1,809 posts
Posted 24 January 2019 - 08:09 AM
I've never seen TETA and caustic used in the same scrubber mixture.  I think it could, but that would create a bigger environmental issue to be handled.  Use one or the other, unless someone replys with some experience in this.
The scrubber liquid is usually a batch system.  TETA can start as a 50/50 aqueous solution and get depleted down until it is not effective enough for your system.  TETA solutions start off about pH 11; exhaustion is usually around pH 7.8-8.8.  In cold climates I've seen 50/25/25 to equal parts TETA, water, and glycol as the starting solution to guard against freezing.  These units are typically outside.
My experience with caustic is like breizh's; about 10%.  Start with 15-18% and deplete it down to about 7-8%, IIRC.
#7 New Chemicals
New Chemicals
  • 4 posts
Posted 24 January 2019 - 02:41 PM
Thanks for the replies. I will use caustic with about 10%  w/w
