Relative Volatility Of A Binary Mixture
#1 chemeng2014
chemeng2014
  • 9 posts
Posted 10 February 2019 - 04:46 PM
I am designing a distillation column to seperate ethanol and water up to azeotropic composition.
I have determined my feed and outlet compositions so then wanted to use the Fenske equation to determine the number of theoretical stages required. However, I have the stumbling block that I need the relative volatility of both components and I need the mole fraction of each substance in the liquid and vapour stages.
My problem is where do we get these mole fraction figures from? Is the vapour mole fraction from the distillate and the liquid mole fraction from the bottoms?
I have Perry's Chemical Engineering book and it says typically 60 trays are required so I'm hoping an answer somewhere beneath this will be realistic once I have the correct data for the Fenske equation (on the basis that tray efficiency is <100%)
This is probably going to be a relatively simple question for most posters on here and I'll probably get slightly ridiculed for it but my brain is mush at the minute so appreciate any help/advice.
Edited by chemeng2014, 10 February 2019 - 04:51 PM.
  • 6,715 posts
Posted 10 February 2019 - 07:26 PM
Consider the resources attached to support your work .
https://checalc.com/...stillation.html
Hope this is helping you .
Edited by breizh, 10 February 2019 - 11:47 PM.
#3 MrShorty
MrShorty
  • 517 posts
Posted 11 February 2019 - 10:33 AM
According to Wikipedia (https://en.wikipedia...Fenske_equation ), you are correct. Xd is the mole fraction composition in the distillate and Xb is the mole fraction composition in the bottoms. The relative volatility is computed as an average, where the Wikipedia article suggests that you can take a simple geometric mean of the relative volatility at the top and bottom to get the average relative volatility.
Does that help?
#4 chemeng2014
chemeng2014
  • 9 posts
Posted 17 March 2019 - 06:22 PM
Thanks all, very useful.
