Air Compressibility Factor
#1 Mohamed cage
Mohamed cage
  • 7 posts
Posted 31 March 2019 - 01:52 PM
I need to calculate the volume of screw compressor in Nm3/h , so based on gas low i have :
V2=V1*(P1/P2)*(T2/T1)*(Z2/Z1)
where V in [m3/h]; P in [ atm abs ] ; T in [K] , and i need V2 in [Nm3/h]
the problem is that i need to calculate the compressibility factor Z  to get V2. i didn't find any helpful document for my case .
  • 6,715 posts
Posted 31 March 2019 - 05:49 PM
Did you consider your favorite search engiine ?
an example:
https://www.enggcycl...y-factor-table/
you may also use the excel sheet attached .
anyway it should be very close to 1.
Edited by breizh, 01 April 2019 - 01:13 AM.
#3 thorium90
thorium90
  • 1,073 posts
Posted 01 April 2019 - 07:00 AM
I found this website very useful. Maybe it might be helpful for you as well. Let me know if you need more info.
https://www.airpack....ity-calculation
#4 Mohamed cage
Mohamed cage
  • 7 posts
Posted 01 April 2019 - 03:49 PM
thank you . it's close to 1 so i will consider it as ideal .
