Partial Condenser
Started by Samir Gupta, Sep 22 2006 01:59 AM
Posted 22 September 2006 - 01:59 AM
I am planning to put into service a partial condenser for a mixture of Organic vapors (BP of 105 deg C max) and air. The organic vapors are supposed to be condensed and separated.
I had used a S&T HE having 6 meters long tubes. Should we go for such long tubes in case of horizontal partial condensers?
The outlet nozzles for process (Shell side) is on top for air + uncondensed vapor and bottom for condensed organics. Shall we put a vapor liquid separator in the downstream of top nozzle?
Can some body suggest the precautions to be taken while employing a horizontal S&T exchanger for partial condenser service.
Thanks in advance...
Samir
Samir
Posted 22 September 2006 - 08:08 AM
Samir:
what you present is a very practical and sensible question that is often battered about frequently at a plant-level basis and is often not resolved correctly until a learning curve is achieved in the experience department.
Attached find my response to your questions. Note that you haven't specifically defined the problem with sufficient basic data. However, this is such an important item for a lot of plant engineers who have been in similar situations, I've taken the time to document it as detailed as I could.
I hope this addresses your concerns and helps you out.
Partial_Condenser.xls 56.5KB
406 downloads
Posted 27 September 2006 - 06:28 AM
Dear Mr Montemayor
Many thanks for your advise. I shall take care of the points raised by you. Additionally, the following info supplements my query:
1. Condensed liquid is not to be sub cooled. In stead it is a feed for one of the distillation columns.
2. Shell side flow is up-down and there is 1-pass on the shell side.
3. Coolant is cooling water. There is no steep increase in outlet temperature of cooling water. Delta T is designed at 8 to 10 degree C.
4. There is no temperature cross.
Thanks dear, once again.
Samir
Samir
Posted 24 April 2011 - 02:29 AM
if the condensing vapor is fed at vacuum than minimize the vacuum as much as possible so that will help you to decrease the lose of your desired organic vapor in non-condensate out let...
Posted 25 April 2011 - 11:35 AM
I echo Art's comment on tube length. I wouldn't use up amd down flow where the shell side baffles would be cut horizontally instead of vertically. This woud create small dams that would hold a condensate level at the top of the baffle cut.
Posted 26 April 2011 - 06:22 AM
Thanks for the info, so interesting;)
Posted 09 May 2011 - 01:43 AM
For big condenser, "X" or "J21" shell type possiblely can be consideried due to pressure drop in shell side expecially for vaccum scenario. Changeable baffle distance also may be applicable.
Personal opinion top downstream separator is unnecessary. Condenser normally have big enough vapour space in right pressure drop.
Edited by JimQ, 09 May 2011 - 01:45 AM.
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
CondenserStarted by Guest_Kentucky08_* , 27 Jan 2025 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
Partial Volume Of Bi-Lobe TankStarted by Guest_bangzhuqiao_* , 16 Oct 2024 |
Air Flow Into A Tank At Partial VacuumStarted by Guest_rajaking666_* , 25 Jul 2024 |
